ACCURA 11 Tyre Inflator
The fitting of tyres is a skilled operation requiring specialist equipment. PCL's range of preset digital inflators offers guaranteed accuracy and meets the demands of bust tyreshops.
Automatic inflation cycles release the operator to perform other tasks while inflating, whilst higher speed and multi-tyre variants can substantially increase productivity.
Key Benefits
  • Consistent cost effective provision of high levels of safe air inflation services
  • Reduced tyre inflation costs - more efficient use of tyre engineers and equipment
  • Long life time costs - long product life with robust design and proven electronics
  • Low and simple maintenance with excellent diagnostics
  • Customisation to meet individual needs and applications
  • Guaranteed accuracy with individual testing
  • Reduced tyre wear extending tyre life
  • Increased fuel economy
  • Increased safety and reduced tyre-related incidents
Key Features
  • Electronic pressure preset
  • Auto start inflation
  • Clear display for easy customer usage
  • Robust, high reliability and modern design with die-cast aluminium housing
  • Ceramic sensor - accuracy to +/-0.5% of full scale reading
  • Attractive and durable membrane with customisable graphics
  • High flow ACCURA 12 & 13 up to 50% faster than traditional methods
  • Over Pressure setting (OPS) - automated seating of bead
  • Nitrogen (N2) purge
  • 230v, 100/120v and 12v versions
  • Can inflate accurately with hoses up to 50m
  • Comprehensive diagnostics and error reporting
Specifications
Accuracy : Exceeds EC Directive 86/217 (to +/-0.5% of full scale reading)
Reading Accuracy : 0.1bar / 1psi / 1kPa
Maximum Inlet Pressure : 16bar / 232psi / 1600kPa
Inflation flow : 400 l/min @ 10bar supply
Approvals
German: PTB 18.08/04.01 (Single and Dual Screen)
French: F-06-H-157 (Dual Screen)
Portuguese: 245.30.04.3.14 (Single Screen)
Spanish: 16-9-009/04013 (Dual Screen)
Product Options
Product No. Description Hose Length Tyre Valve Connector Calibration
D11SS50C Tyreshop Model 7.6m Single clip-on 0-145 psi default &
0-10 bar
D11ST50C Tyreshop Model 7.6m Single clip-on 0-145 psi default &
0-10 bar
Related Downloads
ACCURA 11 Tyre Inflator Datasheet
ACCURA 11 Tyre Inflator PCL ACCURA
