ACCURA Compact Tyre Inflator - D61 series
ACCURA Compact, PCL's most simple electronic tyre inflator to date, combines a modern, user-friendly design with leading sensor technology, electronics and proprietary software in a tiny 255mm x 220mm footprint. It offers the simplest, safest, most accurate means of tyre inflation within a space-saving and cost-effective, lightweight unit.
The robust engineering plastic design offers longer life and low maintenance, whilst the durable ceramic sensor enable extremely precise measurement, with tolerances well above the industry standard EC 86/217.
This makes it ideal for car dealership, garages, car fleets and OEM applications, where ease of use, accuracy and reliability are key.
Key Benefits
  • Consistent cost effective provision of high levels of safe air inflation services
  • Long life time costs - long product life with robust design and proven electronics
  • Simplicity
  • Guaranteed accuracy with individual testing
  • Reduced tyre wear extending tyre life
  • Increased fuel economy
  • Increased safety and reduced tyre-related incidents
Key Features
  • Electronic pressure preset
  • Auto start inflation
  • Clear display for easy customer usage
  • Default to safe-setting
  • Space-saving and lightweight design
  • Robust, high reliability engineering plastic housing
  • Ceramic sensor - accuracy to +/-0.5% of full scale reading
  • Attractive and durable membrane
  • Can inflate accurately with hoses up to 50m
Specifications
Accuracy : Exceeds EC Directive 86/217 (to +/-0.5% of full scale reading)
Reading Accuracy : 0.1bar / 1psi / 1kPa
Maximum Inlet Pressure : 16bar / 232psi / 1600kPa
IP Rating : IP66
Inflation flow : 400 l/min @ 10bar supply
Product Options
Product No. Description Hose Length Tyre Valve Connector Calibration
D61SS20T Compact Model 7.6m Twin hold-on 0-145 psi & 0-10 bar
Related Downloads
ACCURA Compact Tyre Inflator Datasheet
ACCURA Compact Tyre Inflator - D61 Series PCL ACCURA
