AirForce Tyre Inflator
The AirForce dial handheld tyre inflator has received rave reviews from users in tyreshops, garages, car dealers and transport depots.
Fast and simple to use with guaranteed accuracy, this mechanical unit offers longer life, lower operating costs and excellent shock resistance - all within modern functional design featuring a clear analogue display.
Robust but lightweight, the EC-approved AirForce has been developed with ruggedised engineering plastics to withstand high volume, intensive applications, thereby lengthening its operating life.
Its excellent performance means extended tyre life, increased fuel economy and improved safety for tyre users.
Key Benefits
  • Reduced operating costs - fast inflation and deflation rates
  • Increased customer service - high levels of speed, accuracy and safety
  • Reduced cost of ownership - long product life
  • High versatility - flexible usage
  • Guaranteed accuracy - individual testing
  • Reduced tyre wear extending tyre life
  • Increased fuel economy
  • Increased safety and reduced tyre-related incidents
Key Features
  • Clear dial display
  • Modern, lightweight and shock resistant construction
  • Proven Bourdon Tube with beryllium copper construction for robustness and high shock resistance
  • Direct valve design increasing inflation and deflation rates
  • Individual tested and certified
  • Built in swivel and hanging device
  • Bar, psi and kPa calibrations and range of accessories
Specifications
Accuracy : Exceeds EC Directive 86/217
Reading Accuracy : 0.1bar / 2psi / 10kPa
Maximum Inlet Pressure : 15 bar / 218psi / 1500kPa
Inflation flow : 910 l/min @ 13bar supply
Product Options
Product No. Description Hose Length Tyre Valve Connector Calibration
AFG1H03 21" General Model 0.53m (21") Twin hold-on 0-170 psi & 0-12 bar
AFG1H06 9ft Tyreshop Model 2.7m (9ft) Twin clip-on 0-170 psi & 0-12 bar
AFG1H08 6ft Tyreshop Model 1.8m (6ft) Euro clip-on 0-170 psi & 0-12 bar
AFG1D03 21" General Model 0.53m (21") Twin hold-on 0-1200 kPa
AFG1D06 9ft Tyreshop Model 2.7m (9ft) Twin clip-on 0-1200 kPa
AFG1D08 6ft Tyreshop Model 1.8m (6ft) Euro clip-on 0-1200 kPa
Related Downloads
AirForce Tyre Inflator Datasheet
