General purpose 1/2" Impact Wrench
Key Product Benefits
- Maximum torque 540Nm
- Pin clutch hammer mechanism
- Forward and reverse mode
- Rear exhaust
- 4 forward operation impact settings
- Single handed direction change
- Non slip comfortable grip
- Excellent balance
- Positive action trigger (allows variable speed)
- Forward and reverse independent power regulator
Specifications
Material : Aluminium
Size : 1/2" Square Drive
Max Torque : 540Nm / 400ft/lb
Vibration : 1.39m/s²
Sound : 96.6dBA
Mechanism : Pin Clutch Hammer
Free Speed : 7,500RPM
Length : 7.5" / 190mm
Weight : 5.3lb / 2.4kg
Min Hose Size : 3/8" / 10mm
Ave Air Consumption : 3.6cfm / 101.7l/min
Product Options
| Product No. | Max Torque | Free Speed | Weight | Ave Air Consumption |
| APT205 | 540Nm | 7,500RPM | 2.4kg | 3.6cfm |
