1/2" Composite Impact Wrench
General purpose 1/2" Composite Impact Wrench
Key Product Benefits
  • Maximum torque 690Nm
  • Twin hammer mechanism
  • Fully insulated handle/housing
  • Forward and reverse mode
  • Rear exhaust through handle
  • 4 forward operation impact settings
  • Single handed direction change
  • Non slip, warm comfortable grip
  • Excellent power to weight ratio
  • Positive action trigger (allows variable speed)
  • Forward and reverse independent power regulator
  • Progressive throttle
Specifications
Material : Composite
Size : 1/2" Square Drive
Max Torque : 690Nm / 510ft/lb
Vibration : 1.55m/s²
Sound : 98dBA
Mechanism : Twin Hammer
Free Speed : 7,500RPM
Length : 8" / 203mm
Weight : 5.84lb / 2.65kg
Min Hose Size : 3/8" / 10mm
Ave Air Consumption : 12cfm / 340l/min
Product Options
Product No. Max Torque Free Speed Weight Ave Air Consumption
APT233 690Nm 7,500RPM 2.65kg 12cfm
