MK3 Tyre Inflator
The highly regarded, classic MK3 Tyre Inflator has become industry standard in UK garages, petrol forecourts, tyre shops and depots, and is popular amongst operators and tyre fitters for its reliability and accuracy, and sturdy yet slim line design.
The MK3 Tyre Inflator, is robust and highly accurate, offering leading inflation and deflation rates and high performance both indoor and outdoor. Meanwhile the redesigned valve arrangement and larger hose allows air flows up to 30% faster, representing substantial labour-savings for operators.
The "Made in Sheffield" MK3 Tyre Inflators are available with a wide choice of tyre valve connectors and hose lengths to suit all tyre inflation applications.
Key Benefits
  • Reduced operating costs with fast inflation and deflation rates
  • Long life - excellent shock resistance with robust durable design and construction
  • High versatility - suitable for indoor and outdoor environments, commercial and retail applications
  • Guaranteed accuracy - individual testing
  • Easy fitting and usage
  • High pressure variant suitable for aircraft applications
  • Reduced tyre wear extending tyre life
  • Increased fuel economy
  • Increased safety and reduced tyre-related incidents
Key Features
  • New valve design increasing inflation and deflation rates
  • Cast aluminium body
  • Proven linear spring gauge
  • Proven linear gauge display
  • Individual testing and certification
  • psi and kgf/cm² calibrations and a large range of options and accessories
Specifications
Accuracy : Exceeds EC Directive 86/217
Reading Accuracy : 0.1bar / 2psi
Maximum Inlet Pressure : 13.8 bar / 200 psi
Inflation Range : 9.6 bar / 138 psi
Operating Temperature : -10°C to 60°C
Product Options
Product No. Description Hose Length Tyre Valve Connector Calibration
ALG3F03 21" General Model 0.53m (21") Twin hold-on 0-138 psi & 0-9.6 kgf/cm²
ALG3F04 21" Clip-on Model 0.53m (21") Single clip-on 0-138 psi & 0-9.6 kgf/cm²
ALG3F031 14" Forecourt Model 0.36m (14") Short stem twin hold-on 0-138 psi & 0-9.6 kgf/cm²
ALG3F05 6ft Tyreshop Model 1.8m (6ft) Twin clip-on 0-138 psi & 0-9.6 kgf/cm²
ALG3F06 9ft Tyreshop Model 2.7m (9ft) Twin clip-on 0-138 psi & 0-9.6 kgf/cm²
ALG3F061 9ft Tyreshop Model 2.7m (9ft) Single clip-on 0-138 psi & 0-9.6 kgf/cm²
Related Downloads
MK3 Tyre Inflator Datasheet
MK3 Tyre Inflator
